fly6
Everything posted by fly6
cx7 is smaller than edge, if you want to compare, you should compare edge and cx9!
hi: Can you post couple of photo to show how to connect relay and hid set? I have attached the install guide, but i am not sure where i should connect the signal and two ground line! Thanks!
keep the rpm under 2000, is this really work? because it is winter time, if I driving like a granny, it doesn't matter. :shades:
Hi: I am living winnipeg too. How much for ur real gas consumption? my sel awd model is going up to 17.1 L/100 Km!
My 2007 edge sel did not come with the heat mirror? Is anyplace I can add up this function? Is this a big job? any idea how much will cost this?Any common? Thanks!
Is anyone can tell me that is this set is correct?
fly6 replied to fly6's topic in Interior, A.C., Heat, Interior Trim
upupupupup!!! -
I change both of my high beam and low beam with 10000K and 8000K!
that is y I try to put to my fog light. and leave the low bean alone!
here have a website, but I have no idea how to use it! http://www.tdiclub.com/misc/conversions.html
Hi guys: My 2007 Edge is SEL AWD model and 3200KM on my odometer. Until now my gas consumption is 16.6L/100 KM for the city drive, I think this number is too badly! by the way I fill Shell regular gas! Anyone have any idea?
hi: I got same kinds of problem from my hid and it is also cause my engine light come out. When I put back the original one, the light gone. So I think maybe some volt problem cause this issue. By the way my edge has day time running light function. So for now, I use manufactory one for my low bean, and I try to put the hid set to my fog light later today! Does anyone have any udea is that hid light will burn out the lampshade, if I put the hid to my fog light!
Hi: Is any one know the exactly size for sel model? Is front door and rear door speaker same size? Can I use this (MTX Thunder Dome-Axial TDX6502 6 1/2" Speakers)? Mfr. Part Number: TDX 6502 Converts to Components No Crossover Style Info Not Available Frequency Response 48hz-20khz Impedance 4 Ohms Impedance Rating 4 Included In Box Manual Mid Range Size No Mid Range Style Info Not Available Mounting Depth 2 1/16" Power Handling 120 Watts Product Dimensions 22.0(W) x 10.5(H) x 42.0(D) cm Product Warranty 1 Year Parts & Labour Product Weight 2.9 kg Recommended Power Range 120 Watts Sensitivity 92Db Speaker Size 6 1/2" Speaker Type 2-Way Super Tweeter Style No Tweeter Protection Circuit Info Not Available Tweeter Size 25 mm Tweeter Style Soft Dome Woofer Material Not Applicable Woofer Surround Material Not Applicable More Information FEATURES: All models of the Thunder Dome-Axial line are designed to be installation friendly and have one of the shallowest mounting depths available. The graphite style grille sets off the aluminum deposition cone of the speaker giving the Thunder Dome-Axial speakers a look that demands attention to go along with their high performance standards. Thanks!
I use black tape to cover the sensor to keep get enough power supply. -
thanks for your replay. I did not find a way to disable the DRL. The dealership will not do that for me, cause it against the law. for now, I just put back the original low beam bulb back to my edge, and see what happen next. I did not disable my hi beam for hid light. I just leave there, cause I did not use it when I driving in the city. and I think it is will not cause any problem, if I do not use it. I just want to know is anyone install hid headlight for the edge, and nothing going wrong? I wish the code is not cause by the hid light. if it is cause by hid light, can I return the set of hid light back to ebay seller to get refund? Thanks! -
so which brand gas I should use? and is this possible to cause this code happen? -
what is wrong with this brand gas? i am serious, I go to ford dealer 4 times a week. I got piss off. so what u want to say. I bullshit u guys? So if you want help me get out this situation, I am appreciate. If u say any bullshit, please go away! -
First I fill Esso regular gas! Second, the dealer told me the problem maybe cause the hid headlight, they ask me to put back the original bulb in my vehicle. And see what is happen! And the machinist threaten me that if the problem cause by my hid headlight, the dealer will charge back my moeny for the checking fee and maybe cause some warranty problem. Anyone have any idea? It is too bad! -
HI Guys: I bring back to dealer again. This time dealer told me they maybe change the whole gas tank for me. and rent a F150 for me from enterprise car rental company. I wish I can get back my car asap. -
Installed the H&R springs yesterday
fly6 replied to jeffreybehr's topic in Interior, A.C., Heat, Interior Trim
I want to live at US, everything is cheaper than Canada. -
HI Guys: My damn engine light come back again. is any possible cause by air filter. This is time when I start my engine, after few second the engine light come out. I only push botton for the heat driver seat and passenger seat and turn on the air condition for warm wind. I set the internal temperature at 24'C and that is it. Is any chance cause by these action to cause the engine light come out? (sorry for my engligh, I hope u guys can understand what I mean.) Thanks for reply! -
I guess 550CDN is for lifetime service! If I sold my vehicle, I can transfer my sirius radio to the new one! If it is working like this, is this worth 550 CAD to buy off this service.
Do guys think it is worth 550 CAD for the lifetime service?
I think so. and I hope this is the problem. -
When I post this topic I am worry about the problem cause by hid heaflight. Cause it is happenning after I install hid. But in fact, the problem is Evaporative Emission Control System Pressure Sensor Low Input. But the dealer did not find out the exactly problem for this code, they just replace a CAP ASY - FUEL TANK FILLER for me.
