bink19
Everything posted by bink19
Dealer made the repair based on the TSB and wind noise is completely gone.
I called my dealer yesterday and they found the TSB. The repair I believe is they put a piece of rubber or foam into an access door underneath the mirror I believe. This prevents the wind from going into a space on the mirror and out which makes the whistling noise. My car is going in this morning for the repair. This TSB was just posted 2 weeks ago so some dealers may need to search again.
Dealer ordered me a new mirror and put it on the vehicle and now the noise is back since the one they replace the original on would not allow me to adjust it. Asked about a TSB and they said there was none for my vehicle concerning this issue. The noise now is not as bad but still noticeable. If anyone can get a copy of the TSB that is mentioned in this thread please post so I can take to the dealer.
You know where I can view this TSB at? They replaced my mirror with one from an Edge they had on the lot and the noise seems to be gone. Only problem is they did not hook it up correctly as I cannot adjust the mirror left or right. When I push up it goes down and down goes up.
Dealership just replaced my driver side mirror with one from a edge they had on the lot. I'll give an update tomorrow once I get a chance to drive it. Dealer also did confirm that the plastic piece on the mirrors where added for 2011 to reduce noise. Quality guy took car for a drive with me and also determined the wind noise to be coming from the mirror. Hope it works.
Fold the mirror in so its facing the driver side window and see if the wind noise goes away. That eliminated the wind noise for me so the mirror is most likely out of spec and am waiting for the dealer to call me back with replacing it. My service adviser is not the greatest at replying to email and voicemails.
I know when I was driving into the wind I could har the noise but my passenger did not. I will verify though that this is the case. I'll have my fiance drive next time.
I have that in mine, but only noise on the drivers side.
I tested this last night and the noise was still there. I did tuck my driver side mirror in though after reading that the noise was fixed by a new mirror. This seemed to reduce the noise so I emailed my dealer what I found on here.
What year is your Edge and what state do you live in? I just got mine back for the fourth time and the issue still there.
Dealer ordered a new molding part for the back window, I believe that is what they said, and I am taking the vehicle in Monday to get repaired, again. Once I get the work order I will know exactly what the part is and will post an update to this forum on Monday.
Took my vehicle in this morning for the fourth time trying to get the wind noise fixed. I tried taking it to another dealer and they stated "You didn't by the car from us and another dealer already tried fixing this issue Ford will not pay us to look at it and try to fix" I think that is a bunch of BS and my guess is that it is not true. I will update when I get my vehicle back today or tomorrow with what the dealer has done or not done. Seals on the window have been replaced twice already.
At least they gave you a vehicle to use. They kept my Edge for four days and I was told that no loaners are available.
Well for me I have been dealing with Suburban Ford of Sterling Heights. If I got the answer that it is the characteristic of the car I would lose it. Especially since I did not have a radio for 2 months because of the SYNC/MyFordtouch problem.
I called another dealership to get a second opinion and I was told was "if another dealer has looked at this issue we won't because Ford will not pay us". I called the dealership where I took my vehicle the first 3 times and I am waiting for the service rep to call me back tomorrow after he speaks with the service director to decide the next course of action. I'll update when I hear back from the dealer. Hopefully they open a case with Ford on this, even though they said they would on my first visit.
Not sure, but taking mine in to a differnt dealer this week.
If I get time I am taking mine in next week. I'll let you know what they say if I take it in.
Thanks for the response and I will bring this up with the dealer when I take it in next week. I'm taking it to a different dealer as I have had issues with the dealer who have originally tried fixing this issue.
I might give that a try thanks. I have a friend who works for a body and I'll see what he says.
I do not feel any cold air coming in and they did do a water test and found no leaks. The noise was not coming from the heater as I turned that off along with the radio. Maybe I'll try another dealer just to they say about it.
I have a 2011 Edge that has been to the dealership three times already for wind/whistling noise (sounds like the window is cracked open) coming from the driver window area. Dealer has replaced weather stripping twice already and stated the door is aligned properly. This noise always occurs around 50+ mph, and occasionally at 40+ mph. I live in Michigan and could this be caused by the cold weather affecting the weather strips? Anyone else experiencing this problem? The noise is loud enough to be noticied over the radio. Ford has told me to go to another dealership to get a second opinion, but between this wind noise issue and My Ford Touch problems my car has been at the dealership more than it has on the road. Passenger side does not have this problem. Any thoughts?
