2007Edge
Everything posted by 2007Edge
ABS- traction light blinks when turn to left, car jerks.
2007Edge replied to 2007Edge's topic in Brakes, Chassis & Suspension
Yes,today I was checking other things and I checked the tone ring, it is cracked. I have to replace it soon before winter.- 5 replies
- abs
- traction control
Hi everyone, I was changing my parking brake today and while I didn't have a problem to change it on the right wheel, I found that I am missing the part that goes from cable in to the left wheel. It is not in the hardware kit or parking brake kit that I purchased. It should be be connected to the cable, but is not. if anyone knows the name of the part and where can get I it? As pointed on the image attached. Thanks
Thanks, I'll check it.- 5 replies
- abs
- traction control
My problem is when I turn left on the stop sign, traction control light goes on for a second and car jerks for a second. I noticed this problem only when the weather is cold ( bellow 2-3 C or 38 F). The road is dry and no snow. I had this problem last winter and at first sign of spring and warmer weather I have changed the ABS sensor on the front left wheel. All summer was OK and beginning of the winter it started again. If I press on the gas little bit more sometimes doesn't jerk. Is it faulty sensor or something else? Thanks.
- 5 replies
- abs
- traction control
thanks, I'll check if I can find it online.
Hi, I am searching online for this module for ford edge 2007 and it says it doesn't fit ford edge, it is for for explorer 02-03 anybody knows where to buy 7H473 4WD control module. thanks.
I just replaced mine complete burned but still working, the price in ford dealer was 20 something $,found replacement on rockauto for 3.67 (in the lamp & socket for ford escape 2007 2.3 L L4). it fits on ford edge 2007. part AIRTEX / WELLS 1P1466
strange enough my gauge is back to normal. maybe 2 months ago started to work again. In your case could be that unit is stack when you have a lot of gas in the tank. Mine would start working after half of the tank is empty, but now is ok, don't know for how long. found this tsb for this issue http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=140915
- 7 replies
- fuel sending unit
- fuel pump
I did it yesterday, fairly easy job to drain the fluid, little bit tricky to fill up ( took more time than to drain) Don't forget ford edge transmission fluid capacity is 10quarts (9.5 L). I drained almost 7 liters. My questions: Is it safe to use transmission fluid that is left to add to poverstearing fluid to fill up? In the manual shows the same sort of fluid to use.
thanks frozennuts, I a.m trying to figure out what is lower on the picture, can you tell me is it 1 or number 2 that I put on the new picture, thanks.
Hi guys, I want to change transmission fluid on my edge FWD 2007,I am trying to locate drain plug and only thing that I could guess that is maybe the plug(is) I circled with the red on my pictures. Can somebody tell me is it correct? thanks.
Well, it worked for 2 weeks and get back to full again, it is not fuel sending unit I guess, I disconnected wires from the fuel pump and sending unit ( picture 2 on top of the tread ) and still shows full. I think that some wires have bad connections but where to check this? thanks
- 7 replies
- fuel sending unit
- fuel pump
you are right, the picture is different than the actual unit.The part that I ordered fits in ford edge FWD 2007 and it took me maybe 1 hour to replace the unit, starting with removing fuel pump relay, starting the engine 2-3 times to release the fuel pressure in the system, the procedure to replace fuel sending unit was easy part, it took me 5-10 minutes, put back seats and ready to go.If someone has to replace the fuel pump it is the same procedure as this one
- 7 replies
- fuel sending unit
- fuel pump
thanks, I ordered the fuel sending unit today, will do this weekend.
- 7 replies
- fuel sending unit
- fuel pump
My fuel gauge stack on full, want to replace fuel sending unit, anyone can give me tips how to remove wire harness, fuel line and metal ring around . found fuel sending unit 33$+shipping rock auto dot com thanks
- 7 replies
- fuel sending unit
- fuel pump
Stain is close to the front, You could be right about AC but when you touch it is kind of oily , I went under the car and didn't find anything suspicious, and it looks that drops when it is an extreme hot day. I' ll check tomorrow for AC.
my mechanic changed mine for 40$ :>)
Hi, anyone can figure out what kind of liquid is this? I've checked under the edge but can't see any leaking spot? transmission oil, power staring oil , antifreeze or break fluid? battery acid????
I got abs and traction control light on, ordered rear ABS sensor ( my mechanic gave me the code and went on vacation), started to install today and during removal of old sensor stuck with piece of old sensor still in the hole. What is easiest way to remove this piece? any suggestion appreciated, thanks.
