dwright64
Everything posted by dwright64
  1. 2007.... the volume really changes drastically
  2. Does anyone ever have trouble with the volume knob on the Stereo? Sometimes when you turn it down, the volume actually goes up... I know it just must be worn. Anyone aware of any fixes, besides replacement??? It is the normal radio - no touch screen or Nav.
  3. My MKX is a 2007 and has over 100,000 miles on it. To date, the only mechanical issue has been a worn out Tie Rod end. I average about 40K per year, so the car has been good. Just to clarify, my impression from the Service Manager was the AWD controller just wasn't "talking" to the computer - and that triggered the fault. Also, the controller was approx $300 and the other $300 was labor, would assume tracking down the issue. I know it's not fair that I'm ticked, but the expense from the dealers are outrageous. Anyhow, I'm fairly sure it wasn't something I could have fixed.
  4. OK Dealer said the problem is a 4WD controller box - $680.00 It's my understanding, that without it, but AWD will not work. Took 2 days to diagnose, but eventually showed the code they needed to see to know this is the problem.
  5. Thank you... I ended up taking it to the dealer. Will let you know outcome.
  6. The wrench light on the dash came on today - I'm in sales so I'm in and out of the care many times. Sometimes it comes on, sometimes not.... Owners manual just says take it to the dealer - ok no problem. I would still like to know what "triggers" it... Thanks!
  7. Hit the Ford Dealer this afternoon and picked up the printed instructions.... They are good, very thorough. Also spoke with the mechanic, he said he installs tons of them and only take an hour total... basically the same as many of the aftermarket kits. The box installs right behind the drivers tail light. Will install early next week and post update....
  8. OK... so I went out and purchased the "factory" hitch and wiring harness (MKX) before I checked it out here in the forum.... May have been a big mistake, I am running into issues and yes some of the aftermarket parts look much easier to install. I have run into a roadblock on the wiring (see below) but will keep you updated as it is resolved. 1. The Class II Hitch..... Yes, it's a tough install. The hitch come complete with a new rear bumper, so the entire rear bumper cover & bumper must be removed. It's not to bad, maybe took me an hour to remove. Afterwards, just install the new bumper/hitch and the cover is replaced. Couple things... putting the bumper cover back on is tedious. It's tough to fit correctly around the tail lights, but a little patience and stick with it... it does go back on, and looks correct. YES, you do have to cut a small portion out of the lower bumper cover. If you do a good job, the result is MUCH better than the aftermarket kits that I have seen. The small receiver is VERY discreet and when you are not towing, you will not even know it's there. I was very happy with the looks when done - did not look like a tow truck!! 2. The wiring.... as stated everywhere... the kit does NOT come with directions. Internet directions that require a FORD user and password are labeled on the box. Upon asking the guy at ford behind the counter, he had no clue how to get them. He tried and was trying to be helpful but needed a day to get help getting them. So... off to Google, my best friend.... and there is nothing on the net about installing the FACTORY wiring kit. So this is where I am... I'm not going to do it without directions, I've checked the wiring and none of the color coding makes any sense. Of note... when I looked up the part number (from Ford), it said it would work with the factory plug - no splicing wires. Looking at my part - I just don't see how that is possible - something is gonna get cut somewhere. I may end up with one of the other aftermarket harnesses that "snap" into the lights, but that means I "eat" the factory harness as my local dealer will NOT accept returns. So.. I'm not unhappy. I really like the look (or lack there of..) of the factory hitch, but the wiring is unresolved. I'm not in a hurry, and I will get it done, but I'm slightly ticked at my local dealer for not being more customer driven... after all, I'm paying twice as much as everyone else on here that installed the aftermarket kits in half the time or less... Let me know if you would like to see pics... Over and out....
