ZZedge
Everything posted by ZZedge
Ford resealed all 4 tires...let's see how that goes. Btw, I still have warranty until September...my mistake
ZZedge replied to exodus's topic in Audio, Backup, Navigation & SYNC
Install completed successfully. I have a few other issues (trim lifting and leaking tires) so i went to the dealer and will be bringing the car in for the repairs. They did indicate there is a recall on the nav card so apparently i will be receiving a new nav card... -
2011 Edge/MKX My Touch and Sync Problems
ZZedge replied to akirby's topic in Audio, Backup, Navigation & SYNC
I got the same message - i pressed ok and then it was stuck on install 1 of 9 for an hour. Not knowing what else to do, i shutdown the engine and waited for the usb key light to turn off, then removed the usb key, started the engine, and re-inserted the usb key, it started from where it left off and continued. Install completed successfully. Of course, i found the instructions there after where they indicate to do the master reset. Some how it has worked... -
Ok thanks I will try it in the couple of days. Cheers. -
In the summer, I held on to it as I wanted too see if any issues would come up. Also, I had no real issues with sync until a few days ago where my navi no longer works and the backup camera green/yellow/red proximity sensors are no longer working... -
I just opened the package from ford and both the upgrade USB and new navi sd card are included in the package... From what I read several people have had issues with the install...should I do the install? -
I have the same issue with all 4 tires on my Ford Edge Sport 2011 - i have to check and put air in my tires every week... I raised it once when i got my oil changed when 1 tire was leaking and they said they checked it and they could not find anything... Now i'm out of warranty...fantastic...this will be my first and last ford....
Edge Sport 2011 - trim around rear window lifting
ZZedge replied to ZZedge's topic in Exterior & Body
Don't have a pic at the moment, however, it is the vertical trim (left side of the rear door when facing the door). It has lifted away from the body. -
I have a Ford Edge Sport 2011 and i have noticed the trim around the drivers side rear window lifting... Does anyone know if this is covered under warranty?, however, i believe my 3 warranty has just expired in October... Has this happened for anyone else? and does anyone have good suggestions on how to fix it? good glue? Thanks
2011 Edge Limited - HVAC Heat - No in between
ZZedge replied to jsabia85's topic in Interior, A.C., Heat, Interior Trim
i have the same situation with my ford edge sport 2011...i just bring the temp back to LO and bring up gradually...also, use the defrost and leg warming mode...not ideal but an issue i can live with -
Same here - have the iphone 4s linked with no issues so far
Thanks for the info
Agreed - looks nice. I assume he removed the lense and tinted the inside? silly question but just want to make sure.
Looks good - where did u get the lenses, cost, and how difficult was it to install? Cheers...
Is there anyone NOT having MFT issues?
ZZedge replied to Tina's topic in Audio, Backup, Navigation & SYNC
i leave my ford edge sport 2011 in the garage unlocked and only issue so far (knock on wood) was the backup camera scrolling - which has not occurred in a few weeks now. I've had the car since Sept 22. -
Picking up my new Ford 2011 Edge Sport in Tuxedo Black today
ZZedge replied to ZZedge's topic in Welcome Forum!
Thanks - sorry for the late reply - been really busy - car is running really well - loving it. Having trouble positing a pic here - will try again -
From the album: Ford Edge Sport 2011
© © 2007-2008 FordEdgeForum.com
ZZedge posted a topic in Welcome Forum!
Hi everyone....i'm picking it up around 3-4 pm today....can't wait... Anyone have any complaints or advice with theirs??? Cheers...ZZ -
Woohooo just ordered my Edge 2011
ZZedge replied to controleur2001's topic in Buying, Leasing & Ordering
Picking up my tuxedo black ford edge sport tomorrow....ftw!!!!!!!! Hope there are no issues with the software
