jsabia85
Everything posted by jsabia85
Horn lost its "sound"
jsabia85 replied to jsabia85's topic in Alarms, Keyless Entry, Locks & Remote Start
In order to replace I guess I have to take the bumper off? Do you know if there are instructions on how to do this? -
As of yesterday I noticed that the horn on my 2011 Ford Edge Limited sounds really weak. It used to be louder but now it sounds weak or like a little boy that hasn't hit puberty . Also, the horn sound is coming from the passenger side engine area. Is a horn also located on the driver side or is it just the passenger side? Any ideas? Has anyone experienced this problem?
I noticed a couple months ago that the HVAC temperature does not seem to work or mix the hot and cold. I brushed it off my shoulders until today when I was on a 4+ hr car ride. It was cold outside so I put the heat on but it obviously got too hot so I put the temperature down to around 75 degrees (from HI) and the temp was still the same. I continued to lower the temp until i got to 65 degrees and it was still blazing hot. If i shut the HVAC off the turn it back on then the temp would cool down. AC works fine, Heat works fine but there is no in between... Has anybody else noticed this or hear of this happening before?
I am currently at 2,750 miles on my Edge. My dealer stated that the oil should be changed every 3,000. I was reading the manual and it says 10,000 mile oil change intervals. I was wondering what everybody is doing with their edges? Should I change my oil at 3,000 or at 10,000?
Does the Edge have auto lock?
jsabia85 replied to tknice's topic in Alarms, Keyless Entry, Locks & Remote Start
Yes the Bump will be included with your edge... -
Where were your grounds? Did you go straight to the battery or did you drill anywhere?
Where did you mount the ballasts and relay?
Latest update BT4T-14D544-BE. Experiences?
jsabia85 replied to Neil McLaughlin's topic in 2011 Edge & MKX
I just got back from the dealer and unfortunately I had to leave my car at the dealer once again. The service department was closed so I was just given my keys from one of the salesman. I got in my car extremely anxious to test out the new update and see how much "snappier" it is. I turned on my car and IT ACTUALLY TURNED ON. After noticing a slight speed improvement (not perfect, but NOT BAD) I was quite pleased. Unfortunately when I went to turn on my nav to go home, all I got was "SYNC APPS" so I thought it was a new feature but it wasn't. I tried resetting the SD card, turning on and off the car but to no avail it wouldn't turn on! After finding that NAV was not working, my Ambient light is not working as well. I didnt notice any difference in quality of the backup camera tho, it looked the same. Maybe I just need to clean the lense. So I left my car there and hopefully it will be resolved by tomorrow. I am currently driving a 2010 Edge SEL as a loaner and I really miss my 2011 limited! -
I just brought my car in for service this morning. Dealer said it would be about 2 hrs, they gave me a loaner because I had to go to work. I KNEW it wouldnt just take 2 hrs. Long story short, I get a call from the dealer at around 5pm and they said they successfully updated the system and everything looks good. they wanted to hold my car overnight because I brought up thinking that the reason my SCREEN wouldnt turn on was because it was cold out (after around 40 min the screen would turn on). Dealer said they are going to keep the car outside over night and test it in the morning, I was totally cool with that. Anyway, after looking at syncmyride.com, It looks like I have the BE update. BUT It also looks like I never received the BD update. I am wondering if it is possible to skip directly from AJ to BE. Below is my update history: Type Name Version Description Status Date BT4T-14D544-BE SYNC GEN 2 BT4T-14D544-BE CI 1/4/2011 BT4T-14D544-BE SYNC GEN 2 BT4T-14D544-BE CI 1/4/2011 BT4T-14D544-BE SYNC GEN 2 BT4T-14D544-BE CI 1/4/2011 BT4T-14D544-AJ 1.3 SYNC GEN2 CCPU (AJ) CU 1/4/2011 BT4T-14D544-BE SYNC GEN 2 BT4T-14D544-BE CI 1/4/2011 BT4T-14D544-AJ 1.3 SYNC GEN2 CCPU (AJ) CI 1/4/2011 BT4T-14D544-AJ 1.3 SYNC GEN2 CCPU (AJ) CI 1/4/2011 BT4T-14D544-AJ 1.3 SYNC GEN2 CCPU (AJ) CI 11/9/2010 BT4T-14D544-AJ 1.3 SYNC GEN2 CCPU (AJ) CI 11/9/2010 -
How to remove rear liftgate interior trim panels
jsabia85 replied to bschau's topic in Exterior & Body
1998 Edge? They didnt make the edge in 98 -
Since you are not getting the SONY System. the sound will be average at best. The SONY 12 Speaker system really does sound crisp and clear. Although, the bass does not hit all that hard compared to my JL Audio 12W7in my last car, I am quite please with the quality in my Limited. (ALTHOUGH I havent been able to listen to it much because the damn MFT dont turn on)
On the Actually NAV screen, go to menu, then click vehicle settings, there is an option to enable/disable to rearview camera
MyFord Touch is turning into a real piece of crap
jsabia85 replied to rogersmj's topic in 2011 Edge & MKX
Does anybody know where the MFT Computer is located? Is it attached to the screen or located elsewhere in the car? -
IS it possible to view the tire pressure on a 2011 Ford Edge Limited in the instrument cluster? Or does the tire pressure info only come up when there is low tire pressure?
No the problem is, when you turn off the car the screen goes white. If you dont lock your doors I believe the screen stays on. But maybe he locked the doors and the screen just never shut off (thats what caused the battery drain)
Replace the battery? You dont need to replace the battery, just get jumper cables and jump start the car.
Drivers side inside quarter panel area and it's a PIA to get to because the fuse cover is behind the hood release cable and you gotta wiggle the cover around it to remove the cover. -
Canuck, although I have not had the same problem you are having, I'm having other issues with the screen not turning on at all. I did notice that a simple fuse pull, sitting out for 5 min does not work. Try pulling the fuse and let it sit for 30-60 min and see what happens. If I pull the fuse for 30+min it starts to work everytime. I just don't get it, I tooK delivery on Nov 16 and have had issues since day 1. I feel as if the recently delivered edges are experiencing more "critical" issues than others who have taken delivery earlier. I mean it's been 2 weeks and I may have only gotten a good 4-5 uses with the MFT. 90% of my driving is without the MFT and NO AUDIO! I've been using iHeart Radio for my music on my iPhone lol. I almost want a loaner car from my dealer until Ford engineering fixes this issue. -
Actually there is "battery saver technology". I was in my edge the other night getting to learn the system with the car on but not actually running and burning gas. After about 15-20 minutes I got a pop up on the nav say system will be shut down due to low battery, then it had like a loading bar and it started to shutdown. I was quite impressed. Although I have gotten that white screen issue and I think the reason why it doesnt shut down is because sync doesn't recognize the system and being on but the screen is just lit up.
IMO I dont think you have the update we are all waiting for. Supposedly ford has put a hold on all new vehicles built from being shipped out due to this new update. Since this new update hasn't been rolled out to dealers yet it is very unlikely to be installed on vehicles in the customers possession as of yet. I just hope that ford rolls this update out soon!
As much as I hate saying this, I'd much rather have all those bugs then for the MFT to not even turn on. You are lucky because yours atleast turns on, mine doesn't!
