TheWilldog
About TheWilldog
TheWilldog's Achievements
Community Answers
Best way to troubleshoot weak window wash spray?
TheWilldog replied to TheWilldog's topic in Exterior & Body
Nozzles arrived this morning. Quick install and my sprayers are back to shooting over the windshield and onto the roof, just like I remember, thanks. -
Followed your inx for removing the insulation blanket and the problem was immediately apparent. https://photos.app.goo.gl/1vLGwRsfHIEsxLtv1 Ordered some replacements on Amazon. I didn't see Dorman specifically for the Edge but I think these are similar https://www.amazon.com/gp/product/B06XW75S4Q/ref=od_aui_detailpages00?ie=UTF8&psc=1 Thanks -
Hi, 2008 Ford Edge SEL, about 145k miles. I did a quick search and didn't run across this topic on the forum. Has anyone else had to figure out what has caused a sudden drop in window wash spray pressure? A couple of weeks ago my windows wash sprayers appear to have gone out. I checked the obvious like making sure the reservoir was full (it is) and that the spray nozzles weren't plugged (they aren't), so I assume the problem is with the pump, but I don't know for sure. Wanted to check here before I go an try to figure how to replace the pump. I made a video of the current state of affairs - you can see I'm only getting a little bit of spray out of the passenger side nozzle and nothing at all on the driver's side. The back window spray seems to be normal, but that was never really strong to begin with. https://youtu.be/_1-9pBM1LnQ Regards Will
Rear Rotor stuck on the hub, help?
TheWilldog replied to TheWilldog's topic in Brakes, Chassis & Suspension
Never mind, I just decided to go inside and watch golf for an hour, came back out, hammered the ever loving crap out of it one more time, and it broke loose. All patched up and ready to go. I didn't bother trying to plug the extra hole on the new rotors. -
quick follow up - is there a way to remove the thin metal shield behind the rotor without removing the rotor? It's blocking most of the area where I'd either grab or whack the thing. Also, the replacement rotors have a sixth hole in them that isn't plugged. The stock rotors had a rubber stopper inside this hole (they don't appear to be removable). Does it matter if this hole is not stopped up? -
Working on the rear pads and rotors. Got the driver's side done fairly easily, but passenger side rotor will not budge off the wheel hub I've nailed with pb blaster already and whacked it with a rubber mallet but it still won't come off. Are there any other tricks to try? Will
Got the CD Error message a few weeks ago and I've been trying to fix it. I think that ship has sailed. Next step, trying to extract the CDs: http://i289.photobucket.com/albums/ll204/thewilldog/Edge/IMG_2427_zpsc9f5bc17.jpg I've removed the radio from the vehicle, detached the face plate, and removed the top of the radio cage. I can now see the CDs in the unit, but I don't see a good way to remove them without breaking something. Is there a proper way to remove them? Or will any attempt further damage the player?
Need to Replace Headunit in 2008 SEL, Options?
TheWilldog replied to TheWilldog's topic in Audio, Backup, Navigation & SYNC
All my CDs are already Mp3 burns. I had it set so that each disc was a discography for an artist, i.e. slot one was Foo Fighters discography, slot two was Pearl Jam discography, etc. Some discs have ~130 mixed songs from a single genre, so if I'm in a country music mood I could select slot three and listen for 6 hours straight. I haven't used a regular CD for more than 5 years. I used to carry an organizer around until I bought the Edge with the in dash changer. With all six slots filled I had significant variety and quantity of audio content at my finger tips. That's why I stopped carrying a CD organizer. That's also why going back to a single disc would be a big downgrade for me. However, faced with buying a replacement factory 6 disc unit at a ridiculous price vs. a single disc aftermarket unit, I'll probably go with aftermarket. First world problems, I guess... -
Dang! I just had an online chat with a Cruthcfield sales associate who told me that basically aftermarket in dash CD changers do not exist. What a beating! I do not want to fool around with an MP3 player while driving. Oh factory stereos, why do you mock me so? Every car I've ever owned has had some issues with the stock audio. -
Thanks, taking a look at the site now. I'm notcing something right off the bat - does no one make an in-dash CD changer headunit? I was quite accustomed to the changer in the factory unit. In fact I stopped carrying around a CD case over a year ago. However, I'm not seeing any aftermarket changers on the crutchfield site. Is that something only Ford is doing? -
Hello, my 6 disc CD changer (no sync, no nav, no sub) crapped out when I changed my battery last month. The CD player no longer works; the display reads "Initializing" and then "CD Error." I've tried unplugging and plugging it back in a couple times but no dice. I'm way out of warranty, so I need to fix/replace. I'd like to get an upgraded unit, but keep most of the existing functionality. Does a product exist that meets the following criteria? 1) fits double din space without dashkit. 2) supports steering wheel controls. 3) supports the aux in located in the console glove box. 4) supports sub woofer, should I choose to add one later. I don't want sync or navigation. I don't really want touch screen either, but I could live with it. Can any one suggest a unit that fits the above? Or am I being unrealistic with regard to steering wheel controls, aux in support?
Aha! I was able to get a hold of it. Tried a different pair of needle nose pliers. I'll go hunting for a new mast, thanks. http://i289.photobucket.com/albums/ll204/thewilldog/Edge/IMG_2434_zps743348c8.jpg
I don't see an easy way to get at it from inside the car: http://i289.photobucket.com/albums/ll204/thewilldog/Edge/IMG_2433_zpse0f4008d.jpg How much work is dropping the headliner?
Dead Battery Replaced = CD Error
Next step, trying to extract the CDs: http://i289.photobucket.com/albums/ll204/thewilldog/Edge/IMG_2427_zpsc9f5bc17.jpg I've removed the radio from the vehicle, detached the face plate, and removed the top of the radio cage. I can now see the CDs in the unit, but I don't see a good way to remove them without breaking something. Is there a proper way to remove them? Or will any attempt further damage the player? -
Thanks, that graphic showed me exactly where to remove the bezel. I tried to remove the stereo as well but it doesn't to want to come out. I removed the four 7mm hex screws holding the face in place, but on the right side it feels like there's another point of attachment that I'm not seeing. Can someone fill me in? *Update* nevermind, just had to really tug on it to get it unstuck.
