securinu Posted September 2, 2008 Report Share Posted September 2, 2008 Ok I started this new thread to keep track of the edge switches that are not illuminated like the mkx Quote Link to comment Share on other sites More sharing options...
securinu Posted September 2, 2008 Author Report Share Posted September 2, 2008 BAMR switch : Ground pin 1 to pin 14 this is the factory ground wire in a pin to pin 2 and run to the headlight switch to the violet /gray wire this is the dimmer controlled circuit Quote Link to comment Share on other sites More sharing options...
securinu Posted September 2, 2008 Author Report Share Posted September 2, 2008 I pulled apart the seat memory switch and it does not have back lighting and wont work as the switch is screenprinted and will not allow light to pass thru . The mkx switch is silver in color and wont match. I was going to try to swap the guts of the mkx switch to allow but tlike i stated earlier the switch is screenprinted and wont allow light to pass thru. Quote Link to comment Share on other sites More sharing options...
securinu Posted September 2, 2008 Author Report Share Posted September 2, 2008 I pulled apart the driver window switch tonight and the child lockout has the capability to allow light thru but there is no led on the switch . i will work on this and post back. Quote Link to comment Share on other sites More sharing options...
MKX2007 Posted September 4, 2008 Report Share Posted September 4, 2008 I pulled apart the driver window switch tonight and the child lockout has the capability to allow light thru but there is no led on the switch . i will work on this and post back. The window lockout switch does not light up on my MKX. Neither does the mirror control switch. Quote Link to comment Share on other sites More sharing options...
tameejean Posted September 9, 2008 Report Share Posted September 9, 2008 I haven't posted here in forever, but I HATE that my seat memory buttons are not illuminated. I have fumbled in the dark more than once and erased the memory in one for the other because I accidentally hit the "set" button instead of 1 or 2. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 9, 2008 Report Share Posted September 9, 2008 I haven't posted here in forever, but I HATE that my seat memory buttons are not illuminated. I have fumbled in the dark more than once and erased the memory in one for the other because I accidentally hit the "set" button instead of 1 or 2. The memory positions should be programmed to the unlock button on the keys - if not you can do it yourself. That way when you press the unlock button it moves to the correct memory location and you don't have to hit the button on the door unless you don't have the right key. Quote Link to comment Share on other sites More sharing options...
Lex Talionis Posted September 9, 2008 Report Share Posted September 9, 2008 The memory positions should be programmed to the unlock button on the keys - if not you can do it yourself. That way when you press the unlock button it moves to the correct memory location and you don't have to hit the button on the door unless you don't have the right key. this can also be done with with the outside keypad if you have that. this way, the key fob or outside keypad could also trigger mirrors & seat 1 or 2 to move into position for you. that being said, still wish we could convert that switch to be lit nevertheless Quote Link to comment Share on other sites More sharing options...
