Images
Popular Contributors
Link to this FordParts webpage Good luck!
For that VIN and generally for 2020 Edge -- which is the latest listed model year shown -- no mention or depiction of AutoHold switch or circuits/connectors in the China region Wiring Resource, though the China region Workshop Manual includes identification of the Instrument Panel Cluster's AutoHold Reconfigurable TellTale (RTT) indicator lamp in an IPC illustration... ...and as you mentioned previously, a single reference to AutoHold in the China region HTML format Owner's Manual, which is the only format in which the Owner's Manual is offered... Good luck!
A few days ago fairly deep water on the road caught me by surprise - I checked under the car to see if any of the flimsy splash guards were damaged but saw nothing. Today while doing an oil change I notice a small plastic shield was damaged - I've used epoxy and thin wire to get it back together but would like to know the part number and price. Ping @Haz
By Wubster100 · Posted
Last night I upgraded the rear wheel speed sensors with the bi-directional ones. I parked a car on the street to test. My neighbors must have thought that I was the worst driver ever. I drove past the car about 30 times. I am going to have to replace the front side parking sensors with the correct long range ones. Sometimes I would get false detections of parking spots. The system had a difficult time measuring the parking spot. Sometimes it would detect the space, but then it gave up and never told me to shift into reverse. Sometimes it got way too close where the front tire was going to hit the car. However, after many trials, I got a few good results. I got to experience active park assist. It was nice that I could shift between reverse and drive any time so that the system would make its next move. I also tried park out assist and it worked well. Next: 1. An ABS module replacement is not required. We do not need to upgrade to CADS3. 2. Long range parking sensors are required to accurately detect parking spaces. Standard “HU5T-15K859” sensors will work as a parking aid, but they don’t measure parking spaces well. -
That was it. Something wasn’t programmed right. Now, all 12 of my parking sensors are beeping and working correctly. -
@HazCan you post the wiring diagrams of the auto hold button on the Ford Edge CN? I am interested to see which module the button connects to. VIN: LVSHFCAH1KH454157 EDGE CN 2.7L -
Normally, only the front wheels will receive power, unless the AWD system responds to slip between the front and rear axles, or if wheel slip is anticipated before it occurs. -
Thanks for all of the information! Sounds like a trip to the shop is in order. How urgently do I need to get it in? It sounds like with the actuator motor stalled, the car is either stuck in AWD or FWD all the time. If I switch to the AWD screen on the dash, it shows all 4 wheels as blue. I'm guessing that means the PTU is stuck in AWD mode all the time? Correct me if I'm wrong, but it doesn't sound like I need to stop driving it immediately and take it to the shop tomorrow. My son drives it to school and home several times a day (maybe 50 miles a day and no more than 10 miles from home). I have some work travel coming up week after next so will plan on getting it in then.
LMS latest update on new tune. Finally broke the 5 seconds in the 0-60
Welcome to the Forum @chisle! As you describe your 2013 Edge SEL, it should be equipped with the optional SYNC with MyFord Touch, including the features highlighted below in yellow... The expanded vocabulary of 10,000 Recognized Voice Commands includes the ability to control various HVAC functions via spoken words... hat Hopefully, you becoming proficient in the most useful of these Climate Control Voice Commands can eliminate your need to replace the Center Stack Control Panel and also reduce the distraction it has represented. Attached below as PDF documents are several references that may be helpful... Good luck! Climate Control Voice Commands - SYNC2.pdf MyFord Touch - MyLincoln Touch Supplement - Printing 4.pdf 2013 Ford Edge Source Book.pdf 2013 Ford Edge Quick Reference Guide.pdf
Topics
